Selecting the correct wire strippers for 2 different types of wires
I have two different types of wires that need stripping.
One bundle has a diameter of .125" and contains 2 wires inside.
The other bundle contains 2 wires that are shrink wrapped together.
We need to cut these wires to various lengths and then be able to strip and tin them without damaging the jacket(s) on the 2 wires on the inside.
Any suggestions?
Any suggestions?
RE: Selecting the correct wire strippers for 2 different types of wires
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
Wire is 22 AWG
The two wires that are shrink wrapped together are our main concern.
