Circular plates
3
Circular plates
Circular plates
Where can I find information for calculating deflection, bending moments, and shear under uniform pressure and point loads or both? Much appreciated.
RE: Circular plates
Roark's Formulas for Stress and Strain
RE: Circular plates
I agree with PSlem - Roark's book (its my first choice for this type of problem).
For a simple solution - flat plates subject to a uniform pressure - have a look at 'Design of Welded Structures' by Blodgett (the first of the Lincoln Arc Welding books).  Formulas for circular, square & elliptical plates are in the section on Tanks, Bins & Hoppers - Table 1 (p6.5-3 in my copy).
RE: Circular plates
Roark's is by far the best resource for this, but take some time to read through interpretation of the tables, it's not like picking out a bolt shear value from an AISC table!
RE: Circular plates
Ditto Roarks - Table 11.2 in my 7th edition, lots of different edge support and load conditions.  Should have all you need.
RE: Circular plates
Advanced Strength and Applied Stress Analysis by Budynas
It's got a good section of circular plate theory as well as a limited (but very simple) table for circular plates under varying loading and boundary conditions
RE: Circular plates
Thanks all. That was very helpful!
