Foam for Composite tube
I need to put a tube made on composite (Expoxy with carbon fibre) on vacuum and make
vibration test.
I like to put inside the tube the foam to damp the vibration, which is the foam type compatible with the aerospace environmental?
RE: Foam for Composite tube
try foamed beryllium, talk to Brush Wellmann
