Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...keep up the good work with this forum, I think this is the best one around. ...you actually try to help people learn for themselves. ...I commend you on providing a very good, open learning atmosphere, where usually egos are left behind..."
Geography
koldone2 (Mechanical)
4 Feb 08 16:02
I am using an old Schenck 2010 to control a water brake dyno. I need to get an analog signal out for torque, as an input to a datalogger. Does anyone have experience doing this? I found a manual on the internet with PID tuning ect. but nothing about getting an analog signal. I was told that the signal is a 0-10V?
Rink (Automotive)
4 Feb 08 16:43
koldone2,
I suggest that you contact Schenck and ask them what options they can supply or get details about the feedback instrument they use.  This would allow an instrumentation or electrical engineer to develop a solution for you, if not available from Schenck.
Rink
reidh (Automotive)
4 Feb 08 20:16
Usually a load cell is used, which has an analog output.  A signal conditioner is sometimes needed.
We have used Revere load cells with good luck, but there are many many brands out there that will work.
-Reidh
Helpful Member!  koldone2 (Mechanical)
11 Feb 08 9:39
Stephanie at Schenck was very helpful and I am up and running taking data...thanks for the help
Mikelantis (Automotive)
22 Feb 08 6:43
Dear koldone2, I really would like to know which Stephanie at "Schenck" (today HORIBA ATS) helped you out.
Someone from HORIAB ATS, Troy?
The controller you use is our old LSG2010 controller where we still can support you on request.
- mikelantis
1 Mar 08 10:36
Mikelantis,
"Dear koldone2, I really would like to know which Stephanie at "Schenck" (today HORIBA ATS) helped you out.
Someone from HORIAB ATS, Troy?"
Not sure about Stephanie's last name but yes she works at Horiba in Troy (service/support area)
Close Box
Join Eng-Tips® Today!
Join Us             Close
