Inventor crashes during rectang array
I have had multiple instances where Inventor V11 crashes during a simple rectangular array. I am in an Assembly, in the “Machining” browser section, and go to array a cut out. When I attempt to do this the system crashes. I have searched the Inventor Website for a hotfix for this issue, but have found nothing.
FYI: I have SP2 loaded as well as one Hotfix to correct the licensing issue problem.
Can anyone tell me a way around this?
RE: Inventor crashes during rectang array
What constraints are applied to the parts?
Are any constraints applied to other rect. patterns?
Crashes during a rectangular array are more than likely probably caused by improper constraints or adaptive/flexible parts.
Can you post a simplified assembly that shows this crash?
Can you shrink down the assembly so only the patterned parts are there and see if the crash is still happening?
After finding a number of these yesterday afternoon, I ended up rebuilding the assembly this morning from scratch (in less time than it took to fix them). This fixed the problem.
Thank you for your help!
