Air Terminal box location
Why is that in MEP industry, air terminal boxes are not allowed (or recommended) to be located above gyp. board? What if the access door is provided?
RE: Air Terminal box location
If you've heard that this is not acceptable practice, then you may have been mislead. Just make sure access is available, and the construction team should be able to demonstrate maintenance access if requested for building acceptance.
Good luck, -CB
