What is hydrotest pressure at PD-5500?
I am reviewing vendor data sheet regarding fuel gas filter.
I know ASME Sec. VIII describes 1.5 times fo design pressure for hydrotest.
I would like to get information of hydrotest pressure in PD 5500 for vessel.
I assume that maybe both have the same criteria for test.
Is it correct?
Please advise this matter.
JT
Is it correct?
JT
RE: What is hydrotest pressure at PD-5500?
Suggest you have another look at ASME VIII for the test ressure for vessels. It used to be 1.5 times the design pressure but it has changed.
