Rising stem gate valve
Dear All ,
I have two questions :
For buried application , is it OK to use Rising stem gate valve ??
Can we install rising stem gate valve with actuator , is it standard to connect the actuator with rising stem gate valve or actuator is only working with non rising stem gate valves ??
RE: Rising stem gate valve
Yes, they make multi-turn actuators in both pneumatic and hydraulic for gate valves. Most are fail-as-is because it is difficult to store enough energy to close (or open) a valve 50-150 turns on a failure of motive power.
David Simpson, PE
MuleShoe Engineering
www.muleshoe-eng.com
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
The harder I work, the luckier I seem
