Fillet 3D solid model in AutoCAD Mechanical 2007
Hi everyone,
When I use the toolbar to select the fillet command and then try to fillet the corner of a 3D solid model in AutoCAD mechanical 2007, it says "invalid object selected". I'm using a small enough radius for the part size so that's not the problem. I'm trying to fillet the solid the same way I did with AutoCAD 14, which worked great.
I've looked in the file menu of AutoCAD Mechanical and I cannot seem to find a way to fillet the solid. I also created a 3D solid model box and tried to filled one corner, just to make sure that it's not the particular solid I'm working with. The fillet command would not work on the solid model box either.
When I open the drawing in Regular AutoCAD 2007 (not mechanical), the fillet command works fine on the solid.
Is there another way to fillet the corner of a 3D solid in AutoCAD Mechanical ? If this is actually how the program works, it seems ridiculous to me to have the ability to fillet 3D solids in regular AutoCAD but not AutoCAD mechanical. I'm hoping I'm missing something.
Any advice or suggestions would be appreciated.
John
RE: Fillet 3D solid model in AutoCAD Mechanical 2007
I didn't think you could use the fillet command on a 3D object
With regular AutoCAD (not mechancial), you can fillet 3D solid models with no problem. I've done this with Version 14 up to 2007, but for some reason AutoCAD Mechanical 2007 will not fillet a 3D solid model.
I guess Autodesk must want us to purchase Inventor even for the  simplest of 3D modeling operations smile
I just found out you have to type the command "fillet" in order to fillet 3D solids in AutoCAD Mechanical. The toolbar fillet icon is for 2D objects.
I think they should just have one icon and one fillet command that fillets both 2D and 3D objects. This is how regular AutoCAD does it and it makes more sense.
