Max. Pressure for concrete pipes with rubber gasket joints
I'm working in a water supply project with high pressure concrete pipes (up to 350kPA). Initially we thought about weldet joints but theres a fabricant who proposed a rubber gasket joint. The problem is that i think that this kind of joint is not recommendable for pressures above 190 or 200kPA. Anyone knows any Porject with such high pressures using rubber gasket joints or limitations?
RE: Max. Pressure for concrete pipes with rubber gasket joints
Give Ameron a call, they have experience with these types of projects. Here is a contact: Henry H. Bardakjian, Chief Engineer, Ameron International, Water Transmission Group, 10681 Foothill Blvd, Suite 450, Rancho Cucamonga, CA 91730-3857
"A 36-inch (900 mm) diameter water transmission main for the City of Prescott, AZ was successfully tested to 500 psi pressure."
