Edrawings for WF4
Edrawings for WF4
Edrawings for WF4
All,
As a lot of us are using Edrawings for communication with our clients who do not have Pro/E, I think this will be of interest:
From Tristar in answer to my question when edrawings will become compatible with WF4:
Sip,
This is the answer that I received from eDrawings in regards to wildfire 4.0 compatibility.  I will keep you updated if I receive any new information.
Eli
This in response from edrawings:
Dear Eli,
After going through the case notes would like to convey that we are working to support Pro/ENGINEER Wildfire 4.0 on eDrawings for Pro/Engineer. However we have observed issues when publishing some drawing files from Pro/ENGINEER Wildfire 4.0. We have logged this issue with the software vendor since we are dependent when exporting to eDrawings file. Presently we will not be able to release the product eDrawings for Pro/Engineer with support for Pro/ENGINEER Wildfire 4.0 until the issue is resolved.
However since the issue occurs only with some drawing files and the same is acceptable for customers while working we can upload on our FTP server. The product will be available by February 12, 2008 for download.
Please let us know if we could be of further assistance.
Sudarshan Krishnan
I hope this helps some.
Sip Hofstede
WildCAD Drafting & Design, Inc.
www.wildcad.ca
RE: Edrawings for WF4
Hi all,
Edrawings for WF4 is just out.
Sip
www.wildcad.ca
Sip,
I just received this email from eDrawings today so I thought I would send it over to you, see below.
Eli
Dear Eli,
This is an update to your support request.
A new version of eDrawings for Pro/Engineer V 6.1 with support for Pro/Engineer Wildfire 4.0 was released today.
You may download the latest version from the following link: http://edrawings.geometricglobal.com/products/Download.aspx?productid=5&update=1
Sudarshan Krishnan
eDrawings Support
ed.support@geometricglobal.com
