Drawing View Orientation
   I've noticed that when I place a model view into a a drawing, I can go back and change the view.  For example, if I place a front view, I can click on the view and make it an isometric, left, or whatever.  At some point though, this option goes away.  If you click on the view, the "orientation" section in the feature manager is gone.  Anyone know why?  Or, is there another way to change the drawing view once this option is gone?
John Graham CSWP
Mechanical Design Engineer
RE: Drawing View Orientation
That function is only available on the primary views. It will not work for Aligned or Projected views.
It does not "go away" on my system. (SW07-SP5)
cheers
