When posting a question
I know I've seen this somewhere before, but...
It would be extremely beneficial to put your system specs in with the question, if not in your signature.
Knowing what kind of system your running, as well as what version of SolidWorks, would go a long way towards solving your issue. Functionality changes from version to version so what may fix an '07 problem won't necessarily fix an '08 problem; features available in '08 may not be available in '07. Your hardware, too, can often play into issues.
Just thought I'd throw that out there...
Jeff Mirisola, CSWP
Certified DriveWorks AE
http://designsmarter.typepad.com/jeffs_blog
Dell M90, Core2 Duo
4GB RAM
Nvidia 3500M
RE: When posting a question
thumbsup2 I agree its a good idea to provide all system information here, because as you state, it can make a huge different and be an obvious clue to some problems.
I feel adding it to my signature (not pointing fingers) is a distraction in other boards that I also participate in.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
Jeff,
You are right about the specifications. I would always forget to put in the specifications of my machine, so I put them in my signature. We get new machines every 3 to 4 years so it is nice to see what others are using all the time.
Bradley
SolidWorks Pro 2008 x64 SP2.1
PDMWorks Workgroup, Dell XPS Intel(R) Pentium(R) D CPU
3.00 GHz, 5 GB RAM, Virtual memory 12577 MB, nVidia 3400
e-mail is Lotus Notes
Also, remember to search past threads for your answers before asking a new question.
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2007 SP 5.0
Dell 490 XP Pro SP 2
Xeon CPU 3.00 GHz 3.00 GB of RAM
nVida Quadro FX 3450 512 MB
I'm just a little verklempt. Talk amongst yourselves. I'll give you a topic. Pink Floyd, was neither Pink nor Floyd. Discuss!--“Coffee Talk” Mike Myers SNL
