siemens step 7 array of counters
Not a siemens step 7 expert
I can do this same thing in AB RSLogix5000.
How do you create an array of counters in Step 7?
I can not do it as a DB object. Is their another way besides creating each one in the symbol table?
RE: siemens step 7 array of counters
The other thing with Step 7 arrays is that you cannot easily use indirect addressing (except if you use SCL programming format).
You would have to use AR1 type indirect addressing to access the data.
ST allows you to do somethine like ARRAY_DATA[OFFSET] to access data.
