Help on loading a model in Mechanica
OK, we are having some difficulty on what should be an easy problem. We want to find out the effects of a bolt in tension when a force is applied to the piece to which it is attached.
The problem is, how do you load a bolt in tension? If you put a force pulling downward on the bolt, it stretches the bolt in the wrong place (at the end, rather than in the nut)
Does anyone have a suggestion for the best wat to load and constrain this bolt?
RE: Help on loading a model in Mechanica
Tobalcane
"If you avoid failure, you also avoid success."
