Bizarre error using Python session.XYDataFromPath
Hi friends!
I've got a quick question regarding the extraction of xy data from a path using a Python script. I've successfully done it for both invariant and component field output variables but my script breaks down for status type variables like damage initiation (HSNFCCRT for instance). I'm pulling the data from SC8R continuum shell elements but end up with some bizarre errors. Here's what I've got and I've tried a few things here:
nodalPath = session.paths['Glass_0_deg_1']
session.XYDataFromPath(name='Glass_0_deg_1_HSNFCCRT', path=nodalPath, includeIntersections=False, shape=DEFORMED, labelType=TRUE_DISTANCE_X, variable=(('HSNFCCRT', INTEGRATION_POINT),))
OK, that one won't work because I haven't specified the level of refinement, category selection label or the section point label. Fine. Here we go again:
nodalPath = session.paths['Glass_90_deg_1']
session.XYDataFromPath(name='Glass_90_deg_1_HSNFCCRT', path=nodalPath, includeIntersections=False, shape=DEFORMED, labelType=TRUE_DISTANCE_X, variable=(('HSNFCCRT', INTEGRATION_POINT, ((NONE, 'HSNFCCRT'),),{'shell < S2-GLASS > < 5 section points >':'SNEG, (fraction = -1.0)', }), ))
This gives me an error stating that it is expecting INVARIANT, COMPONENT OR NO_REFINEMENT for the refinement type. If I change it again to reflect the message:
session.XYDataFromPath(name='Glass_90_deg_1_HSNFCCRT', path=nodalPath, includeIntersections=False, shape=DEFORMED, labelType=TRUE_DISTANCE_X, variable=(('HSNFCCRT', INTEGRATION_POINT, ((NO_REFINEMENT, 'HSNFCCRT'),),{'shell < S2-GLASS > < 5 section points >':'SNEG, (fraction = -1.0)', }), ))
It fails again citing "OdpError: Unsupported refinement type: NO_REFINEMENT" This error is somewhat counterintuitive since that particular output variable is clearly not an invariant nor a component and thus no refinement is all that should be valid...yet it is not? What's going on here? I've screwed something up here but can't figure it out! Any insight would be very much appreciated, thanks in advance ABAQUS wizards!!!
RE: Bizarre error using Python session.XYDataFromPath
I am not sure what's wrong. As far as I remembered I had to display the contour plot of the variable to be extracted from path, before using XYDataFromPath(...), despite the fact that XYDataFromPath(...) was correctly written. Otherwise, I was getting an error or even ABAQUS was crashing.
I think is something like this (you have to check the doc for correct syntaxes):
#obtain the default viewport
viewport=session.viewports[session.viewports.keys()[-1]]
viewport.setValues(displayedObject=myOdbObject)
viewport.odbDisplay.setPrimaryVariable(...)
viewport.odbDisplay.display.setValues(plotState=(CONTOURS_ON_DEF,))
#now call XYDataFromPath()
session.XYDataFromPath()
For example, if you choose to display only a specific display group before calling session.XYDataFromPath(), the method will extract data only from that display group...I think.
Your also 100% correct about displaying specific display groups in order to generate region specific XY data. I'm in fact exploiting this due to discontinuities in adjacent regions in my model which would otherwise generate data with non-unique Y values for each corresponding X.
Thanks again for your help, does anyone else know of a way to get around this without the viewport call?
I takes less than 1 hour on a machine with a single core CPU@3.4Ghz and 4Gb RAM.
