WORKBENCH - Scripting API & Customizing Reports
I to every one.
I'm looking for Books, Examples, On-Line Documentation regarding Java Scripting.
What stored inside the Official Manuals purchased with the Program are insufficient for my Works (I have to create Complex Macro in wich the Model that i have to create changes in function of the results of preliminary-calculations and I also have to create Special Reports that shows the preliminary-calculations, insert a lot of ripetitive justifications and collect a lot of Data coming our from the Result of the FEA - based on ADPL command PRSECT and *GET plus some combinations).
Do someone can help me to collect all possible documentations regarding Scripting API of Design Modeler and an Report Customization?
This will help me to waste lot of time in formatting reports that are all the same, but contains a lot info informations that may be implemented via Software.
Many thansk in advance.
RE: WORKBENCH - Scripting API & Customizing Reports
if I recall correctly there was a similar thread in teh ansys workbench portal on the ansys site recently. There you will also find a lot of examples of jscripting inside WB. Since there is hardly any documentation on the WB API, scripting in WB can cause some headaches.....Wish you lots of fun...
Arnold
