what weld joining technique suitable for steel wire rope joining?
i am looking for a welding technique that can be applied for online joining of steel wire ropes. i am looking for a welding or soldering technique which will give rise to a sufficiently strength joint. the ropes are arround 4mm in diameter and having app. 40 small wires twisted in bunches(the steel wire rope type is shown in the attached picture)
in our location we use these cables to produce rubberized steel cords for rubber track production. there we face a critica issue in case of sudden exhaust of these wire bobins. in this case if we can have a joining technique for joining the ends of the old and new wires it will be very benificial.
looking for your knowledgable advice on this.
thank you..
thank you..
RE: what weld joining technique suitable for steel wire rope joining?
Welding may help for uninterrupted production, but the welded section should be discarded if full strength of the rope has to be assured, because welding heat anneals the hardened steel and reduces its strength.
Did you ask the rope equipment manufacturers how they suggest to solve the problem?
http://www.welding-advisers.com/
Ed Danzer
www.danzcoinc.com
www.dehyds.com
http://www.sonobondultrasonics.com/
offers among other products the
SpliceRite⢠WS2016 / WS2026 Wire Splicer
solid state (cold) welder.
You may wish to explore if it solves to your needs.
