Basics of hydrotesting of pipelines
Dear Friends!
I want to study the basics of hydrotesting of pipelines and equipments, like how pressure raises inside a pipeline filled up with water though water is incompressible...
Can you suggest some website to enlighten me in this regard,
thanks in advance,
yours truly,
A.Thirumaran
thanks in advance,
yours truly,
A.Thirumaran
RE: Basics of hydrotesting of pipelines
Now that you mind is opened, the search can begin.
HAZOP at www.curryhydrocarbons.ca
Find the bulk modulus of water over temperature (it doesn't vary much with pressure), compare the pressure adjusted volume of water at STP injected into the test segment with the radial expansion of the pipe vs its internal pressure and as the length and diameter of the pipe and the bulk modulus of the water change with temperature. Nothing else to it.
http://virtualpipeline.spaces.msn.com
"We can't solve problems by using the same kind of thinking we used when we created them." -Albert Einstein
