Hot pumps cooling water flow estimate
Hot pumps needs cooling (e.g. API PLAN "M"), how can we estimate the required flow of the cooling water?
regards,
        roker
RE: Hot pumps cooling water flow estimate
I assume you are trying to cool the seal area - if this is the case I would suggest that contact the seal manufacturer who can guide you for the seal type / size etc that you are using.
