Differences between weld overlay and weld deposit?
Could anyone explain the differences between weld overlay and weld deposit? When and where can weld overlay or weld deposit be used? Thanks a lot.
RE: Differences between weld overlay and weld deposit?
Weld overlay is normally used in the context of adding filler metal on a substrate to either provide corrosion protection, build-up base material for dimensions or provide wear resistance.
Weld deposit is normally used in the context that filler metal was deposited using one or more fusion welding processes.
jt
