Line Thickness for Balloons
Hello All,
Can the line width for balloons be specified? I do not see it listed in document properties. Are its properties linked to another type of annotation? I am running SW2008.
RE: Line Thickness for Balloons
Chris
SolidWorks/PDMWorks 08 2.0
AutoCAD 06
ctopher's home (updated 10-07-07)
ctopher's blog
I tried that already. Balloons are not controlled by dimension properties. Oh well, Thanks anyway.
I don't think they can be changed in SW.
Chris
AutoCAD 06
ctopher's blog
Thanks again.
You could change the font to Ariel Black Bold to make individual balloons stand out, although it doesn't change the line width.
Sylvia
It may not display as thick on screen but when printed out they will be thick as long as they are on the Balloons Layer. You can check if they got moved by clicking the Light Bulb to toggle the display on and off.
The same method applies to BOM Text and thickness. When creating a BOM the last option in the Property Manager is Layer.
Michael
This doesn't work for me. Perhaps you have some other setting checked? I have SW2008 SP1.1.
Sylvia
