Plumbing a solenoid valve for PC50 excavator thumb
3
    I have a Komatsu PC50, 12,000# excavator.  There is a foot control valve that operates the offset for the boom and I would like to plumb a solenoid valve to run a ram for the thumb or the offset alternately off the same in/out lines currently on the offset ram.  I think I need a two way, two port valve but I am having trouble finding the right one amongst all the valves out there.  Can anybody help?
RE: Plumbing a solenoid valve for PC50 excavator thumb
Look at the Cross SD4 (Manual) or SD5 (Solenoid Operated) diverter valve to see if this is what you are asking for.
http://www.crossmfg.com/valve.html
Bud Trinkel, Fluid Power Consultant
HYDRA-PNEU CONSULTING
You need a two-position six-port valve.  Two position to select side shift or thumb.  Two ports for system in-out from the foot valve output, two ports for the side shift, two ports for the thumb.  The side shift and thumb both have double-acting cylinders.
Or consider a thumb/tilt kit from HKX: http://www.hkx.com/cms/images/stories/products/componentpdfs/thumbtiltflyer.pdf
Ted
  Thank you very much to Bud and Ted both for steering me towards the right part
I just did this on a pc50. I found a solenoid diverter valve from surplus center that worked. If you have any questions let me know.
Phil
Thank you sir, I found a new valve.  Cost over 300 bucks and I still haven't plumbed it in, if I could just plan a little down time...
