Maximum flow for globe valve
Could somebody help to calculate the maximum flow through a 1" globe valve say 1/2" port size? Basically I have a small barrell with a 0.02 m3 volume at 1440 psig. There is one 1" globe valve connected with the barrel. If I open the globe valve to atmosphere, what would be the maximum flow through it?
Thanks.
Thanks.
RE: Maximum flow for globe valve
By the way: 113 dB, Sonic flow. Wear Earmuffs.
the gas in the small container you start with will expand to 2.969 m3 when it reaches thermal equilibrium. Initially it will be cool and not expand quite as much.
