Inspection of silver solder joint
We are currently using a silver solder to braze tungsten carbide inserts to a 4140 parent material. I would like to know the best NDT way to inspect the soldered joint.
RE: Inspection of silver solder joint
Also they take tungsten carbide tipped saws and hit them hard with a piece of oak. If the joint is good then the test is NDT.
We have info on brazing carbide and troubleshooting at www.carbideprocessors.com
Tom
