interpolation from a curve in excel
dear friends,
I have a curve, but i have not any formula or function,
how can i find a good fitting function and extract new data from this curve.
for example:
from a curve we can find that:
f(a1)=b1
f(a2)=b2
f(a3)=b3,...
then f(x)=?
Thank you,
for example:
f(a1)=b1
f(a2)=b2
f(a3)=b3,...
then f(x)=?
Thank you,
RE: interpolation from a curve in excel
http://preview.tinyurl.com/2prpo4
From the website:
"Three Dimensional Interpolate and Extrapolate Functions; Two Dimensional Interpolate, Extrapolate, Cubic Spline, Polynomial Curve Fitting, Line Intersections, Minima, Maxima, First Derivative, Second Derivative, and other functions."
TTFN
Not almost anymore!
corus
You can also turn to other sources beside Excel for curve-fitting. For some online tools, check out:
http://www.zunzun.com/
http://www.savetman.com/curvefit/index.html
http://w
http://www.xuru.org/rt/TOC.asp
I have used zunzun.com to perform the same task. As stated previously, it helps to know the model that the data came from.
http://sourceforge.net/project/showfiles.php?group_id=187105
If you would like to make your own curve and surface fitting web site, the tutorial for this is at
http://wiki.pylonshq.com/display/pylonscookbook/Pylons+Curve+and+Surface+Fitting+Tutorial
Please let me know if you have any questions or suggestions for the site.
James
