density difference of cast steels (CF8M & CK3MCuN)
Do you have any experience or knowledge in different density of cast steels due to different alloy elements.
I need to know density difference between ASTM A351 CF8M & ASTM A351 CK3MCuN.
The same pc casted in these 2 different materials, has the same weight or different weight.
I suppose that CK3MCuN should weight more. But how more?
Thank you
Thank you
RE: density difference of cast steels (CF8M & CK3MCuN)
That's why depending on the source, you will get different values. E.g. for CF-8M I found values between 7750 kg/m³ up to 8030 kg/m³.
The only value I found for CK3MCuN was for it's wrought equivalent AVESTA 254SMO and was 8000 kg/m³.
I take 7.8gm/cc as the density for CF8M and 8gms/cc for CK3MCuN. The value for CK3MCuN has been taken from the reference below.
http://www
Save water Drink Beer
