Requered Minimun Thickness en Plates
Greetings.
..What minimum thickness should I use to decide that plate is refused or not? For Example, If I'm testing a 1/4" plate from outside drum of a boiler (Mitchell, 11 ton), could I refuse a plate when its thicknesses are equal 50% or below this one? is there some code that lets me know it?
thanks in advance
thanks in advance
RE: Requered Minimun Thickness en Plates
http
http
More to the point, I'd suggest having somebody inspect it that specializes in this kind of work to begin with.
