Smart Fasteners Help
SW 2008 SP2.0
Why when I insert my smart fasteners into a whole, they are inserted backwards?  Is there a way to change this?
RE: Smart Fasteners Help
Have you tried hitting the Tab key while inserting them?
Dan
www.eltronresearch.com
I think.  When do I begin to tab?  When I do press tab, it just goes to the next field.
I click the Smart Fasteners icon, then "select" the hole i want, then click add.  Then when I tab it just goes to Top stack selection, then bottom stack, ect.
I don't use Smart fasteners, I just pick out the right fastener/washer etc. from the toolbox. If it's installed upside down, I just flip one of the mate's auto-generated alignments (edit mate or right-click on mate) until its fitted correctly.
This mate-flipping works for smart fasteners too. I just tried it.
I'm with pietje, I don't use smart fasterners.
You can hold down the "ctrl" or "tab" key (I forgot off the top of my head) when inserting the parts and it will flip into the position you want when inserted. Or you can flip it manually as mention in this thread.
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2007 SP 5.0
Dell 490 XP Pro SP 2
Xeon CPU 3.00 GHz 3.00 GB of RAM
nVida Quadro FX 3450 512 MB
I'm just a little verklempt. Talk amongst yourselves. I'll give you a topic. Pink Floyd, was neither Pink nor Floyd. Discuss!--“Coffee Talk” Mike Myers SNL
Forgot to mention this is when you drag and drop method
Mechanical Designer
Similar subject but I also use drag and drop. BUT even when the holes are drilled with the hole wizard metric countersink screws always go in upside down with the head buried in the plate and the screw sticking out in the air. I have been complaining since 2000 and embarassing their demos whenever possible but its never changed. I know we can press the tab or altermate button but why should we. There is only one way to fit a countersink screw so why cannot the (expensive) program get it right!!!
Hmmmm I feel better now
Well put.
Azum and Alvan9, I understand your pain. There are a lot of bugs (I mean a lot) in the software that were never fixed and keep prorogating into newer software versions. I've also complained for years about the little bugs, I found and SW chooses to ignore through my enhancement requests. There main focus is to create new software every year which I don’t agree with. Yes, there’s some new cool stuff, but feel they’re adding bells and whistles we don’t need. Example: drawing backgrounds that look like old manual drawings with coffee stains? I need to design products and create drawings, and really could give a rats a%$ about added software items like this. Don’t get me wrong, it’s killer software, and I love to use it everyday, but SW’s vision… I think, is going into the wrong direction.
Mechanical Designer
Colin,
You'll be happy to hear that, for 2009, SW is focusing on stability/reliability/fixes and not more bells and whistles (though there are a few of them as well)
Jeff Mirisola, CSWP
Certified DriveWorks AE
http://designsmarter.typepad.com/jeffs_blog
Dell M90, Core2 Duo
4GB RAM
Nvidia 3500M
Jeff, that is great news my friend. Sorry I sound alitte bitter, but these so called little bugs drives me crazy.
Mechanical Designer
