Fluid velocity for pemeability
For an analysis, I have material properties with elastic and permeability features. When looking at the results, does anyone know how to extract the fluid velocities? I can't seem to find out how to do this! I would appreciate any help.
AGY
AGY
RE: Fluid velocity for pemeability
If you do not see it then before running the job you should request this output under Request Field Output.Then rerun the job you will find it
make sure it is requested
