Nonsinusoidal voltage and SMPS
Dear Sirs,
can you help me in questions of the influence of input voltage distortion
(THD and odd and even harmonics) on SPMS operation? What levels of those
quantities is acceptable? What harmful consequences is due to high voltage harmonic level?
What literature (books, standards and Internet source is available on this item?
Thank you in advance.
RE: Nonsinusoidal voltage and SMPS
http://standards.ieee.org/reading/ieee/std_public/description/staticp/519-1992_desc.html
http://grouper.ieee.org/cgi-bin/netforum/ieee519/a/12
http://ece-www.colorado.edu/~ecen5807/
To my mind small power single phase SMPS without PFC circuit will usually tolerate much higher levels of voltage distortion compared to other equipment and will operate at levels much higher than given by the standards. The input circuit is basicly a diode rectifer with capacitive smoothing which will accept a heavily distorted voltage without complaint.
Depending on the phase of the harmonics, the harmonics might increase DC-link-voltage beyond design value. But the harmonics usually existing on line voltage tend to reduce DC-link voltage because usually distortion leads to a trapezoidal waveform and not to a triangular.
For SMPS including an PFC-cicuit or with three phase input, there might a greater susceptibilty to harmonic voltages.
Muhammad H. Rashid "Handbook of Power Electronics", Academic Press, 2001
