Wrap a Label Around Cylinder Without a New Configuration
Good morning, I have a model with a cylinder and in an assembly I want to warp the label around the cylinder.  Is there anything in SW2008 that can do this or do I just make a new configuration for the label?  Thanks in advance for any help.
RE: Wrap a Label Around Cylinder Without a New Configuration
You could make a config of the cylinder with the label, or create the label as its own part and add it into the assy.
How and when the label is applied in the real world should dictate which method you use.
cheers
If you have PhotoWorks, you can apply the label directly to the cylinder in the assembly. Drag the label onto the part, then use mapping to position.
Jeff Mirisola, CSWP
Certified DriveWorks AE
http://designsmarter.typepad.com/jeffs_blog
Dell M90, Core2 Duo
4GB RAM
Nvidia 3500M
Thanks for the replies.  I need the label in the BOM and it is the last thing put on the part, in the real world.  Currently, I am just using a different configuration, but I was just wondering if there is a better way using something else to wrap it around the cylinder and unwrap it, so that in the exploded view it would open flat and  unexploded it would be wrapped. Well, thanks for the suggestions.
Use the Sheet Metal function to create the label as a separate part. You will then be able to use the flattened config when needed.
cheers
Thanks CorBlimeyLimey, I will give that a try a little later, but right now I am in the middle of a big bug with PhotoWorks and I have to get it over to SW first.
