Problem using load function with GUI
I have created a GUI that allows a user to input a file path, click an 'Import' button, and load the data into MATLAB for manipulation.
I am having a problem using the load function to import the file. When I call this function, I am getting a 'Attempt to add 'file' to a static workspace' error.
Is there a better way to import the data than with the load function or am I doing something wrong?
My load function looks like the following:
Where path is the user input for a file path.
Thanks in advance,
Chad
CODE
load(path)
Thanks in advance,
Chad
