Masked subsystem that cannot be opened by others
Hello, does anybody know how I can create a masked subsystem in Simulink that cannot be opened by other persons. I would like to give away a model that can be simulated by others, but prevent them from seeing the code.
/Jonas
/Jonas
RE: Masked subsystem that cannot be opened by others
you can put that block in a read protected libary, then it should not be able to look under the mask.
Kind Regards
