Need of design factor from AISC 326 (or AISC S326)
I would need to know the design factor for analysis of a steel structure of a compressor train base plate, in normal/ultimate /accidental condition from certification AISC 326. Then I could find the allowable stress for each design load.
Thanks in advance.
RE: Need of design factor from AISC 326 (or AISC S326)
What is a design factor?
What I call design factor is the factor applied on Yield stress of used material. That permits us to calculate the allowable stress or design stress in order to keep structure withstanding.
Bending or flexure uses 0.66Fy, if shape has compact sections.  Use 0.60Fy for lengths of Lc to Lu. Use chart is unbraced length is greater than Lu, (check shear also).
You should probably purchase the manual you are looking for.
