Can't divide by expression inside scetch
So I have this wonderfull scetch and I am trying to use a percentage of the OD to keep the distance the same when I change the OD.
My OD expression is p46=4.114
What I would like to do is p178=(4.114/p46)*.99
Why when I try to do this it gives me an error that says "Dimension error" "The units of the formula are not consistent with the units specified.
Thanks!
Thanks!
RE: Can't divide by expression inside scetch
I don't understand why you don't use p178=p46*0.99
The reason I can't use p178=p46*0.99 is because I am reverse engineering something. So my initial value of p46=4.114
I am then going to change p46 so p46 in the end might be 5
If I use p178=p46*99 for p46=5 my answer would be 4.95, but my value should be 1.203 using p178=(4.114/p46)*.99 as that is about a 20% increase.
Hopefully I explained that ok.
What you're going to have to do is go into the Expression Editor and create an expression which has a Dimensionality of 'Constant', something like XXX = (4.114/p46)*.99, and then set p178 equal to XXX (BTW, it's OK for an expression that requires units to be set equal to an expression that has NO units).
Give that a try as I think it will solve your problem.
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
Thanks!!
