Question about SlopeW
If any of you familiar with Slope/W:
I have a simple question but yet puzzling
If you want to locate a point (for example when you drowing a slope geomtry) you have to move the cursor until finding the right coordinates of this point (this is really hassle).
Is there a way where one can locate the point by entering its coordinates directly.
RE: Question about SlopeW
One thing that I really like about Slope/W as opposed to older programs like XStabl, is that you do not need to know the exact coordinates of each point in order to develop the model. I will typically sit down with the plan and a scale and use the "sketch" feature in Slope/W to rough in my layers, etc. Then I will adjust as needed and draw in my regions (used in the calculations) using the procedure described in the first paragraph.
