Multi Block .pdf plot
Is there a way to plot to .pdf a multi-block acad file, whereas there are two title blocks in on model, and have each block have its own pdf page?
The only way I've found was to have two separate acad files and plot to pdf then use adobe to combine them. I'd like to keep the blocks together as they are apart of the same drawing.
RE: Multi Block .pdf plot
