material data base
material data base
material data base
how do I add physical property lines to the data base? how can I open it up in a spread sheet and make the changes then save it back. I tried to copy it to the desktop and change the extension to .xls so I could open it up in excel. It worked but when I saved it and changed the extension back to a .sldmat file type solidworks didn't recognize the file type.
Any help would be appreciated.
B. Long
Dell Optiplex 745
2 gig Ram
Solidworks 2007
AutoCAD Mechanical 2005
Springfield, Mo User Group
RE: material data base
Use a simple XML editor for the file. Change the extension to XML for editing. I often use Aptana IDE.
Stefan Hamminga
EngIT Solutions
CSWP/Mechanical designer
Searching Eng-Tips forums
B. Long
Dell Optiplex 745
2 gig Ram
Solidworks 2007
