Selecting a Glycol Makeup System
Are there rules of thumb to consider when selecting a glycol makeup system? I have a very small glycol chilled water system consisting of only 500 gallons. I have looked into glycol makeup systems ranging from a Wessels 6 gallon unit to a B&G 55 gallon system. Prices range from $500 to $3,600.
What criteria do I need to consider?
RE: Selecting a Glycol Makeup System
www.axiomind.com
The above has some sizing guidelines for glycol fill. I've attached the guide I use.
Just some pipe and valves.
If you have a tight system, adding glycol should not be a major concern, but you do need to check it for inhibitors on a regular schedule.
Ken
Ken
KE5DFR
