Pushover analysis
Pushover analysis
Pushover analysis
Hello all,
I want to perform a pushover analysis in ANSYS of a building, with increasing forces for each load step, using the first mode shape, till the building collapses. Any suggestions and advices are welcome.
Thank you
RE: Pushover analysis
I think you can just use multi-load steps.
Ansys will give up all the results of every substep.
hello Zachary07,
sure i can use multi-load step, but i need the force for which the building collapses. I don't need reactions or so...
