O ring materials for high temperature
I am looking for an O-ring served at a temperaure of 800F. What king of material I can use?
RE: O ring materials for high temperature
Metal o-rings are an option. I used them successfully for a high temperature Inconel heat exchanger. At 800F you are probably talking about silver coated Inconel or Inconel X. There are many items that must be considered in order to make a reliable seal (e.g., surface finish, optimal o-ring cross-sectional diameter, vented or non-vented o-ring, thermal expansion of flange and bolting, etc.). Metal o-ring are not forgiving like elastomeric o-rings.
Do a Google search on "metal o-rings" and contact manufacturers. They can help make sure you consider all relevant design considerations.
Download the Product Manual as it gives a very through explanation as to seals work and their applications.
http://www.helicoflex.com/products/
