wet and dry efficiency of recuperative air to air heat exchanger
I would be very grateful if somebody can explain me something about heat exchager efficiency. How to calculate dry efficiency (efficiency without condensation) and wet efficiency (efficiency with condensation) of recuperative air to air heat exchanger?
Thank you in advance.
RE: wet and dry efficiency of recuperative air to air heat exchanger
In air to air exchangers, condensation is rarely an issue unless the hot air also picked-up humidity along the way.
- Steve
