Progress Bar count lines of code
Hello! I woud like to make a progress bar hack that uses the width of a textbox as the size of the bar. My question is how can I have the progress bar show while my macros are working in the background? Additionally, I would like the bar to increment for each line of code read, so the progress would be relevant to the code being processed. Has anyone found a good way to do this? I have found several examples online, but nothing that will encompass these criteria. Or, would a regular ProgressBar control in VBA be the best choice? Thank you for your input!
RE: Progress Bar count lines of code
Umm, updating a control requires a line of code.  You want to update the control each time a line of code is processed.  Your program will do nothing but update the progress bar.
So how do I update the control as each line is processed? That is what I am unsure of. I would like my Progress Bar (or TextBox) width to change for each line of code processed. What I don't know is how to read a line of code as a number and send it to the bar to change its width. Additionally, is there a way to run both the foreground Progress Bar and the background macro simultaneously? Thanks.
