ADA guidelines for Detectable Warnings
What is the/your interpretation of the requirements of the ADA for Detectable warnings.
I have a bank of perpendicular parking stalls with a sidewalk attached. The sidewalk is on the same grade as the pavement (no curb). Is the edge of this bank of parking considered a vehicular way? Do I need to provide detectable warnings along the length of the sidewalk to be complaint with the ADA? If curb stops are installed 2' off of the sidewalk for each parking stall is that an adequate feature to seperate the sidewalk from the parking lot?
RE: ADA guidelines for Detectable Warnings
ta@access-board.gov
(800) 872-2253
"...students of traffic are beginning to realize the false economy of mechanically controlled traffic, and hand work by trained officers will again prevail." - Wm. Phelps Eno, ca. 1928
"I'm searching for the questions, so my answers will make sense." - Stephen Brust
Do I need to provide detectable warnings along the length of the sidewalk to be complaint with the ADA? No
If curb stops are installed 2' off of the sidewalk for each parking stall is that an adequate feature to seperate the sidewalk from the parking lot? Yes
ht
