Pro Engineer WF 3.0 with vista home premium 32bit (Problems!!!)
Hi to all of view!!!
I got , for a while!!!, windows vista home premium in a new portable pc , i just decided to change O.S as soon as possible, but for now i must get rid of it.
The problems starts with the cabling module , when i start using the 3d pan the program prematurely exits, and when i gone to see the std.out file i saw this:
Error: WINDOWS_SCALE = 0.25 is outside of allowed range 0.50 to 1.00
Graphics type 'starbase' is not supported on this platform; using default.
ERROR - D:\Pro-e Folder\Models - Projects - Drawings\---- Cabling Tutorial\Rev. 01\config.pro, linenum 22: Keyword 'SKETCHER_README_BUTTON' is not valid.
PANIC: global exception handler called, just exiting
Someone can help me
To know meaning of this words???
Any Suggest
Tanks in advance
Bye
Someone can help me
Any Suggest
Tanks in advance
Bye
RE: Pro Engineer WF 3.0 with vista home premium 32bit (Problems!!!)
It also looks like you might have some spaces in your folder names. Pro/E still doesn't like them.
Tanks for the time spent!!!
I will try now. But you now anything about this:
Because i think that is the cause of premature exit.
Can you suggest to me a good grafic configuration of the config.pro??? i use pro-e for create mechanical electrical cabinets & design enginering with surfacing tools.
Tanks anyway!!!
Have a nice day!regards!!
I solved the problem with your help!!!
Tanks sir!!
