Breaking Views
Breaking Views
Breaking Views
when I use "Break View" on dwgs, I cant find how to keep other views in sync with the parent broken view. ie I create the parent view, then break it, then create the projected view which will then have the break also in it.  But then if I change the break location on either view, the other does not change with it, and the only thing I can find to do is to recreate the projected view which can be a real pain if I have dimensions in it.  Also, if I have created both view then decide to break one, it would be nice if they both broke accordingly, again, cant seem to find how to do.
Thanks for any help on this.
RE: Breaking Views
Right-click on the child view, select "Properties", then check the box for "Align breaks with parent."
RE: Breaking Views
thank you so much ... perfect
