Help needed with Matlab script (Some may consider basic)
Please help me I am in dire need of assistance, with the following problem.
I need to create a schedule such that employees at training sessions can hold a series of head-to-head discussions.
Each trainee is to talk with every other trainee and everyone must be involved in each round of talks, except when there is an odd number of people.
Most training sessions attract 20 people or more. I have to write a Matlab script which prompts for the number of trainees and then prints out the pairings in each round of discussions. It needs to generate schedules for any number (odd and even numbers) of participants. I have been told to use Latin Squares as the base of the script.
Knowledge on Latin Squares can be found here:
http://www.cut-the-knot.com/arithmetic/latin2.html
I know that the question is a bit long winded, but I would be extremly grateful if a suitable matlab solution, or any ideas to this problem could be posted to me within a week.
RE: Help needed with Matlab script (Some may consider basic)
I was unable to quickly implement a round robin based on the Latin matrix method. The following code is based on the comments at http://www.magma.ca/~acna/rrsched.htm.
Please check the code with several examples to convince yourself that it is correct. I've tested it for the two cases indicated. I was having trouble for an odd number of people. You can see I kludge a fix in, and added an additional player 'BYE', so there is an even number of people.
You can put the correct names of the people in near the top of the code, and they will be written to a file.
Cheers
J. Vorwald
% Program starts here
function main
% Test 1 - Even number of players
names1 = str2mat('Player 1', 'Player 2', ...
'Player 3', 'Player 4', 'Player 5', 'Player 6');
rounds = roundRobin(names1);
fid = fopen('round2.txt','w');
fprintf(fid,'Test 1: Even number of players\n\n');
printRoundRobin(fid,rounds,names1);
% Test 2 - Odd number of players
names2 = str2mat('Player 1', 'Player 2', ...
'Player 3', 'Player 4', 'Player 5');
rounds = roundRobin(names2);
fprintf(fid,'\nTest 2: Odd number of players\n\n');
printRoundRobin(fid,rounds,names2);
fclose(fid);
function printRoundRobin(fid,rounds,names)
fprintf(fid,'\nRound robin for players:\n');
number_of_people = size(names,1);
for iplayer=1:number_of_people
fprintf(fid,'\t%s\n',deblank(names(iplayer,:)));
end
[number_of_people, names] = fixNames(names);
fprintf(fid,'\n');
[numberOfRounds, numberOfMatches] = getTourneymentSize(number_of_people);
for iround=1:numberOfRounds
fprintf(fid,'Round %d\n',iround);
for imatch=1:numberOfMatches
player1 = rounds(iround).matches(imatch,1);
player2 = rounds(iround).matches(imatch,2);
% fprintf(fid,'\tMatch %d: Player %d plays %d\n',imatch, player1, player2);
name1 = deblank(names(player1,:));
name2 = deblank(names(player2,:));
if (strcmp(name1,'BYE'))
fprintf(fid,'\tMatch %d: Player %s has a bye\n',imatch, name2);
elseif (strcmp(name2,'BYE'))
fprintf(fid,'\tMatch %d: Player %s has a bye\n',imatch, name1);
else
fprintf(fid,'\tMatch %d: Player %s plays %s\n',imatch, name1, name2);
end
end
end
function rounds = roundRobin(names)
% This routine is based on comments at http://www.magma.ca/~acna/rrsched.htm
% Think of a circle, with one person in the middle, and the other people in a circle
% around him.
% In the first round, the person in the middle plays the first person on the circle
% The 2nd match is the two people from both sides of the first person on the circle
% The 3rd match is the next two people from both sides of the first person on the circle
% And so on for the rest of the matches
% In the second round, the person in the middle plays the second person on the circle
% The 2nd match is the two people from both sides of the second person on the circle
% The 3rd match is the next two people from both sides of the second person on the circle
% In the third round, the person in the middle plays the third person on the circle
% etc
% To accommodate N players (N even), you need a minimum of N-1 rounds. To accommodate
% M players (M odd), you need a minimum of M rounds.
% When there is an odd number of players, add a person named BYE.
outsidePlayers = [1:number_of_people-1];
playerInTheMiddle = number_of_people;
circleOfOutsidePlayers = [outsidePlayers outsidePlayers outsidePlayers];
outsidePlayer = number_of_people - 1 + iround;
person1 = circleOfOutsidePlayers(outsidePlayer);
person2 = playerInTheMiddle;
rounds(iround).matches(1,1) = person1;
rounds(iround).matches(1,2) = person2;
for imatch = 2:numberOfMatches
outsidePlayer1 = outsidePlayer - (imatch-1);
outsidePlayer2 = outsidePlayer + (imatch-1);
person1 = circleOfOutsidePlayers(outsidePlayer1);
person2 = circleOfOutsidePlayers(outsidePlayer2);
rounds(iround).matches(imatch,1) = person1;
rounds(iround).matches(imatch,2) = person2;
end
end
function [numberOfRounds, numberOfMatches] = getTourneymentSize(number_of_people)
if (mod(number_of_people,2) == 1)
numberOfRounds = number_of_people;
numberOfMatches = (number_of_people - 1) / 2;
else
numberOfRounds = number_of_people - 1;
numberOfMatches = number_of_people / 2;
end
function [number_of_people, names] = fixNames(names);
number_of_people=size(names,1);
names = str2mat(names,'BYE');
end
