Welded pressure vessel with peaking
Hi!
I need to model a pressure vessel with a peaked weld. How do I model a butt weld and how can I create a peaked shape.
RE: Welded pressure vessel with peaking
It depends - what's the purpose of the evaluation?
To see how a crack propagate.
2D axisymmetric is probably to way to go.  Material properties for the weld and heat affected zones will be troublesome, but not an insurmountable probelm.  Is this with respect to an API-579/ASME FFS-1 evaluation?
