Ratings for power cables
Would someone be kind enough to give me a link to allowable current loads for power cables. I need to check for 240 volt 1Ph 5.8 kW.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Ratings for power cables
You must check your local codes.
Bill
"Why not the best?"
Jimmy Carter
cable ampacity. On the surface #10 thhn would do the job but you have not give all the info required to make the decision.
Like David said!
Bill
"Why not the best?"
Jimmy Carter
Thanks again.
